This is tooooo good not to share.
I hang out on HomemadeTools.net - Encyclopedia of Homemade Tools and Imabass just made a DIY Barbed Wire Fence Unroller that is by far better than the Co-op or Tractor Supply offers! Yet it's very simple to make from welding or wood or thick PVC.
I'll be making mine from PVC that fits on my box-blade. Needing 2 barb-wire spoolers and 1 hot-wire spool.
Here's his blurb ... :thThumbsU
I built this a few months ago. I have modified it from the one in the video by adding 2 additional arms so I can unroll all 6 wires on my fence at once. Each roller is adjustable to accommodate all the standard rolls of wire. This worked great as I was able to unroll all the wires at once and keep them from tangling up. I have tons of fencing to redo and this will be an amazing time saver. It is really doable as a one man team and really speeds up the process.
Basic materials list:
1' of 2x2 square tubing for the receive tube mount.
4' of 2-3/8 oil field pipe for the main mast.
6- 6" pieces of 2-7/8 oil field pipe to swivel around the 2-3/8 pipe.
6- 14" pieces of 1x1.5 tubing for the swing arms. These are welded to the 2/7-8 swivels.
6- 12" pieces of 1" round tubing for the rolls of wire to rotate on.
6- 1" fender washers. I added these from the video posted. These are welded about 2" above the arms and the rolls of wire rest on them.
This was mostly all scrap metal that I had laying around.
There are some wire roller trailers out there that sell for $150ish and only unroll 1 strand at a time. I don't have that kind of spare time to use something like that.
See it in action ...
