sounds good to me
I'll try this the next time I "pop the top" Total time to do this was 10 minuets.I personally have never lubed them, it will just attract dirt and dust, use some fine emery on the crank until the center piece of the starter clutch spins freely. Also washing the unit reguarley will also cause this problem as water gets into the clutch causing it to rust up.
Well, you have two methods that should solve the problem. Let us know which you use and the results.I have a troy built tiller that started doing that this fall![]()
Agree,I tried both ways.Seems to work better with dry balls.lolI personally have never lubed them, it will just attract dirt and dust, use some fine emery on the crank until the center piece of the starter clutch spins freely. Also washing the unit reguarley will also cause this problem as water gets into the clutch causing it to rust up.
