I found out tonight that the driver's side wheel bearing is bad on my mom's dodge stratus. With the tire off the ground, I can wiggle it back and forth at least 1/2". The passenger side bearing seemed fine, as I couldn't wiggle the wheel back and forth with the vehicle off the ground. Could this cause the lower control arm to scrape against the rims? When I tried to put the stock rims w/ winter tires on, the driver's side rim was scraping against the lower control arm. It is off of the front, as I marked it last year? If the wheel bearing isn't causing the scraping, what would be?
Thanks and sorry for so many questions!
