Here's some ideas (after you eliminate any obvious ones like low fuel, or leaning off the seat killing the safety switch, etc.)
1. Higher compression requires higher spark voltage. A marginal coil may produce just enough voltage to fire a plug at low speed but as the engine speeds up and compression pressure increases the coil may be so weak the plug does not fire, until the engine slows down again.
2. You could have a loose wire rubbing, shorting the magneto as the engine revs up and shakes, then...as it slows down again the wire doesn't touch and allows the Magneto to make spark again. Could possibly be internal with the coil. There should be a wire coming out of the magneto coil, short to ground to kill spark. Disconnect the wire from the wiring harness to elminate shorts anywhere in the circuit. Also inspect the spark plug wire for any worn spots it could be arcing.
3. I'm also thinking that a bad Valve lifter is "pumping up" and leaving a valve open at high RPM or a weak/broken valve spring? Just a thought.
