I split the Kubota this week and have a couple of questions maybe someone can answer.
One of my questions is the U-joint cover in the pic below when I removed it was full of 80/90 lube. There is no fill or drain for this and I assume you have to keep it lubed due to no grease zerk on it. Do you just pour lube down the neck of it after reinstalling it? It has a seal on the front and then the driveshaft tube seal on the rear and was not leaking before but I want to make sure the rear front axle seal is not bad and blowing the lube into the cover. I cannot find anything in the service manual about adding lube to it.
Second question: The large bellhousing seal is $41 and wondering if its purpose is to keep dust out of clutch housing?
Third question: Can you buy a clutch alignment tool? I am swapping flywheel and clutch assy's to new motor.
thanks!
thanks!
