I just installed a rod, piston, rings and new gaskets in a project 318 I've got that had a broken rod. I also adjusted the valves.
It starts very quickly but only really runs well with the choke activated but no matter what position the choke and throttle are in it sputters and backfires.
The throttle really does not do too much and the choke actually seems to increase the speed of the engine more than the throttle (they are connected to the appropriate parts, not backwards).
I put new plugs in and gapped them as well. I'm going to drain the fuel tomorrow to see if that helps.
Any other suggestions would be greatly appreciated.
Thanks
Thanks
