I bought a late model Simplicity Landlord with an 18 hp Vanguard vertical shaft engine in it. I need to replace this engine and want to swap a used engine engine in it if possible or maybe something new, but less expensive than the Vanguard.
The engine code is 35077
The engine type is 1152-E1
It is 18 hp, a V-twin, has a 1 inch diameter x 1-5/32 shaft.
I don't mind going down in hp for now and have found a free donor tractor (MTD) with a B & S 14.5 OHV I/C Quiet engine in it. I can't find the shaft length/diameter listed anywhere or what the alternator amperage is.
This engine code is 287707
The engine type is 0224-01
The Vanguard on my tractor has an alternator that is 16 amps, but I'm told a 9 amp will work. The tractor has an electric PTO and dash and head lights. For this swap, I can do without using the head lights if that will reduce the load on the alternator. I've also seen engines with 5/3 amp alternators - not sure what the design intent/use of that configuration.
So what to do? Can I use the above 14.5 engine or should I look else where?
Any advice would be greatly appreciated.
Thanks!
Bill
Thanks!
Bill
