1 - 2 of 2 Posts
I took my battery off my good mower to crank the 18hp Briggs intek. It spins once and stops. The battery is brand new and cranks my 17.5 Briggs fine. So I tried spinning the flywheel by hand. Same thing. Spins over once then sticks. But it's not a dead stop. It's just a "sticky" spot. Any ideas about what to check.
Thanks
Senior MTF Poster
I expect you need to adjust your valves. I have detailed instructions at the address below, put in proper format and remind me what you want AND the model number of your engine.
Walt Conner
wconner5 at verizon dot net
1 - 2 of 2 Posts
