simplicity 6216 motor 402707
I have cleaned the fuel tank lines and carb. It wont run without messing with the choke and it wont idle down without stalling. I can rev it pretty good on the carb and the govener works but it wont run good all the time. It now wont restart with out shooting the carb with starting fuid. I can only see one adjustment on this carb and i have turned it all the in and out and it made no noticeable difference. My only thought is im missing a carb adjustment or i need to rebuild the fuel pump. Could it still rev up if the pump is bad? What would be the symptoms of a bad pump? Thanks for any help
