I have a broken aluminum valve push rod. From all I have read this is the intake valve push rod, part #692011. The exhaust valve push rod is #692003 and is made of steel.
My question is, why can't you use a steel one on both valves? They are the same length and then you wouldn't likely bend one again!
ideas?
[Hey Walt, I see your name on all the forums about mowers! Thanks for being such a wealth of knowledge – and patient!]
ideas?
