61 - 80 of 80 Posts
Post Hole Digger, off 3PH - if not already mentioned.
Beaumont { :>)) www.petperfectexpress.com
Golden Rule - "he who has the gold, makes the rule"
1992 JD 318 original paint w/484 hr. on P218g Onan & #49 snow blower / 1998 JD GT262 w/brand new Kawasaki OHV & 48" rebuilt deck
1986 Toro 824 snowblower 38080 model, Honda HS624 track drive blower, STIHL 2 stroke F5 85 & F5 35 grass trimmer, HONDA CT70 MiniBike,
1987-'89 TORO 20526C push mower 21" Recycler w/Suzuki 4 stroke, 1980 LawnBoy 21" model #7260G w/D409 engine,
1965 Malibu S/S, 1985 Monte Carlo S/S original paint, 1987 Pontiac GTA original paint L98-TPI, 1966 Beaumont Custom original paint,
1967 Beaumont Custom, 1967 Beaumont Custom original paint, 1967 Beaumont 396-350HP Sport Deluxe M21-411's - SOLD 1970 GTO Judge RAIII
Someguyfromolympia,
Power steering kits!!! How about anything to help the steering systems for garden tractors?
Okay, so it's not really an attachment, but you said "Wishes??".
Wormy
I say power steering kit and 3 point for jd 300. I was quited 900 dollars for a 3 point for me on this, i thought this was crazy. If you could do it for like 400-500 i would serously consider it.
Do you mean for the x-300 series ? I thought the trans was not ground engaging thats why deere does not offer one ?
Nope not the x300 but the older 300. It has dual spool hydraulics, 16hp single cylinder. It is the same chassis as the 317.
3 point Cat 0 receiver hitch like the Cat 1 you make. Then a Sleeve hitch adapter that could slide in the receiver hitch. Crawler made one, I think it would help guys commit to getting a 3 point knowing they could easily/qucikly slap a sleeve hitch implement on
How about a rigidly-mounted, dump-capable wheelbarrow for the front of a garden tractor. It would have to be steerable, a pivotal wheel perhaps? It would be more usefull than a trailer in tight places where you can't back out or turn the trailer on the rear. Basically turning the tractor into a motorized wheelbarrow or muck truck, and able to carry a larger load than the Johny-bucket. I have the idea in my head,as well as the use for one I just don't have an efficient way of cutting steel.
A cat 0, 1, and 2 scarifier that has the same removeable tines as those used by a boxblade. In other words just the scarifier portion of the boxblade. Make it in several different widths for different sized tractors. I would need a 6' one. That way if you bend or break a tine you could buy a replacement locally.
My wishlist would include a universal FEL but honestly for the cost it would probably be cheaper to buy a used bigger machine off craigs list. Thats the problem with those little tow behind back hoes. They are $5k+ for that kind of money you can get a full size used machine.
The Johnny buckets look ok but again, not worth the cost. At least not to me.
I think the best thing a small fab company could make and I wish they did was good old fashion solid cabs for small tractors, less than $1k too. These silly tarps over pipes look horrible. As much as I want a cab I am holding out till I can find an original or something solid that can be adapted. Along the same line some sort of universal ROPS would be nice.
a 3 pt mounted clamshell bagger with a pto driven "powerflo" type impeller. like the DR leaf vac, or the cyclone rake, but drive it off the pto and make it mount to the 3 pt with a simple dump from the seat mechanism.
My spoon is too BIG!
what would i like for my sears cat. 0 3pt?
-self powered finish mower/brush hog
-sleeve hitch adapter
-rear scoop bucket
-box blade
-gannon scarifier
-self powered tiller
i couldnt agree more.
maybe even an electric sleeve hitch kit
Ive been thinkin about a modular system, Where you (plug) the engine in, swapin from one attachment to another, like a bush hog, finish mower, hydraulic pump, tiller, stump grinder, log splitter, chipper/shreder, etc. maybe a 14 hp single with electric clutch, and throttle control, Having just one engine to keep in tune, would be nice, :cool: and a cheep way to have multiple attachments. Eric
Always Learning
Something that I can use with this. Box Blade, Self powered bush hog, rear blade scraper for drive leveling, etc.
I second the Self-Powered brush hog!:fing32:
Also, a sleeve-hitch to 3-pt adapter
a quick-hitch for cat-o
universal carry-all
A 3-pt with weight brackets, and something like this on it...
:praying::praying::praying::praying:
How about cheap suit case weights,?? YEA,..we can do that,.. I have a shape cutting machine, Electric eye follows a paper templete. I can cut up to 12" thick, but dont want to, LOLOLOL 1-2" thick all day long, much eaiser to move the plate around on the table, for that matter I can cut any part (one demensionel) that you want, up to 6 foot, you provide the pattern,. Eric
61 - 80 of 80 Posts
