I am going to buy a x728 because I need the AWD. I have a 47inch snow blower I am using on my 1985 420. My question, is the blower compatible with the x728? One dealer tells me yes, but I need a quick hitch. Another dealer says that it is not compatible and will require extensive modification. The blower works fine and has no issues, so I would really like to save $2,000+ if I could. Thanks in advance.
Well the quick hitch can be used for several attachments so you might want to look at the versatility you pick up by having one.
Addictionado
Maybe the reason you received 2 different answers is that there are 2 different 47" blowers for the 420 the older one uses a hitch that only fits the 420 the other uses a QuickTach hitch like the 425/445/455 do you know which one you have?
