Roy,Yeah, I'm pretty sure it is 540 at WOT. Didn't think about a non-contact tach. Thanks Harry. :fing32:
Just went out to look and make sure. No indicator, just a turtle and a rabbit.Roy, I thought I remembered that there was a "PTO" indicator on the throttle. No? . . . .
Yeah, I'm thinking there is not a PTO indicator on the X700 series throttle because the rear PTO is an add-on. Any way, I ordered one of them fancy smancy non-contact tachometers, so it should answer the question when I get it. :fing32:Okay, I guess I was thinking of another tractor. Must be the hare, then. . . .
I'm glad it did the job for you Roy. Despite the surprising results, at least know you know ..Ok, I got me one of those non-contact tachometers (BTW, they are pretty cool) and run some tests.
Just ask here. :biglaugh:Ok, I got me one of those non-contact tachometers (BTW, they are pretty cool) and run some tests. At WOT, the X748’s engine RPM is 3360 and the 540RPM rear PTO is turning 588 RPM! The PTO turns at 540 when the engine RPM is throttled back to 3100.
Since the X748 does not come with a factory installed tach, how and the heck are you going to know that unless you have installed an aftermarket tach?
I had a 3-point MacKissic Mighty Mac chipper/shredder hooked up when I did the testing. Wasn't feeding anything through the shredder.. . . Did you try checking the pto rpm when it was under load, or just spinning freely? . . .
Good info Roy. :thanku: My non-contact tach was delevered but has not been used yet. A nice compliment to the Tiny Tach.:fing32:Ok, I got me one of those non-contact tachometers (BTW, they are pretty cool) and run some tests. At WOT, the X748’s engine RPM is 3360 and the 540RPM rear PTO is turning 588 RPM! The PTO turns at 540 when the engine RPM is throttled back to 3100.
So, if you are running a 540RPM attachment and the manual says “do not exceed 540 RPM” I guess you should throttle it back a little, or get a tach. :fing32:
Roy has added a Tiny Tach to Big Greene so does have engine RPM info available - no tape needed. :thThumbsUGlad you got it figured out, Roy. I guess for now maybe you can use a piece of tape to line the throttle up properly.
For what you gave for that x748, I would have expected a little more tech.
