I have a JD LX288 with the 48 PWRFLO QT (M00PFK) attachment and rear bagger that I seem to be having issues with the belt I was hoping somebody can assist me with.
I incorrectly found the JD part number for the belt to be M147278 and picked up the ½”x 90” equivalent (A88) which ended up being too long (was not for the QT Quick-Tatch version- my bad)!!
I finally found the correct JD part M138974 which I was told was an 80” belt so I purchased an A78 equivalent belt and installed it, however upon engaging the belt it smoked and started to burn up. Checked all the spindles and they appear fine (free flowing) and was thinking the belt may be the wrong size (little loose). I found some information that the belt is actually 79” so I would need an A77; however before I purchased yet another belt I wanted to see if anybody know the proper equivalent belt for M138974 , my thoughts that a 1” OD difference (effective diameter ~0.5”) should not be an issue and that there is something else possibly going on? Thanks in advance.
