Ariens S16H part# for contact points & carb ?
2210 Views 5 Replies 3 Participants Last post by  Lamimartin
Hi
I went trough all S16H Ariens 931010 owner's manual, parts manual, shop manual, Kohler k341 owner and shop manuals. I saw ignition schematics and even specifications for ignition contact point adjusment, but I can't find the part number for the contact point and condenser that must be replaced periodically.
What is the Ariens contact point & condenser part number and description in the part listing, so I order one set for next tune up ? I have not seen any evidence that Ariens S16h is equipped with an electronic ignition module. I'm only trying to be one step ahead of trouble with basic spare parts. Alternatively, If you know about an electronic ignition conversion kit, to get away from contact points I'm interested too. I've got the timing gun but I have not seen any details on how to process timing on my engine. This makes me suspicious about the absence of part number for ignition contact points and condenser. Could it be outdated schematics that should have mention electronic ignition module ?
I'm also surprised to see there is no part number or detailed description for any engine related part in the Ariens manual. Kohler K341 manuals are not providing any details on the carb model or part number used on S16H. So far, I found out it is likely a Kohler # 30 carb, but there are two choke level configurations available. I have little clue on what version is applicable on my S16H. If you happen to have more details, it would help. I don't want to make a decision on purchasing spare parts just looking at how a carb look like. At least, I'm certain there is really a carb in my tractor, the question is only to know which one for sure. I might only need a new float kit :fing20:
1 - 6 of 6 Posts
condenser- 230722S Replaces A237083, 237083 Used K91, K141, K161, K181, K241, K301, K321, K341, K482, K532, K582 with battery ignitions.
KOHLER IGNITION BREAKER POINTS 4715003 / 4715003S
you probably need to take the air cleaner off to see enough details to know what carb you have, i have been lucky that all mine needed was a cleaning.
Re: Ariens S16H part# for contact points & carb ?
Thanks !!!!
I put a Transistorized Ignition module ( Nova II Part No. 31-8786 ) on my S 16 H no more setting Point gap & is very easy to hook up.
OOHHHH !
That's cool ! I like reducing maintenance. I was reluctant to get into old fashion contact points and condenser.
Very good suggestion, if the price is reasonnable
Thanks a lot !
Kohler K341 16HP engine has different ignition type versions. Nova II Part No. 31-8786 is apparently NOT compatible with battery ignition type. I looked into the shop manual and I'm not sure of what I have.
Incidentally, have you removed the ignition points or just installed the 31-8786 in parallel ?
Thanks
1 - 6 of 6 Posts
