I have a G14 with the hydraulic pump that is the geared version of the S14 and the PTO like that on a S14 wouldn't fit it. since the PTO drives off the rear shaft of the hydro unit.
Thanks, I have a hydro, looking at a geared parts tractor, the guy said it had a rear PTO, but as I figured, it's a different setup. Are the Front and Rear PTO 540 or 2000 rpm. What implements can I use on the rear PTO shaft of the Ariens, can I build a 3 point frame on a big shaft drive mower deck and use it as a finish mower. I have a tiller for the Ariens, but it is run from a double pulley over the shaft
The PTO on the hydro models runs whatever speed the engine runs which can roughly vary from 3200 RPM Max to 3600 RPM max depending on the engine
