1 - 14 of 14 Posts
My Ariens GT 17 is leaking oil. How do I stop this leak? In the pictures, I removed a snap ring and washer from the shaft. The oil is leaking out right around the shaft. When it is running it is a steady flow around the shaft.
Thanks
Looks like you have a seal to replace. Have never had to replace one but here is the pump
drawing and part numbers.
The repair manual doesn't do a good job of covering disassembly and I have never had one of these apart. I am pretty sure some one on here has though. The Sunstrand was used in other period tractor brands. I will try a search in the stickies section later.
Yes, I have meant to look at one of mine as the GT19 gas tank is still loose for repairs to see how the outside clip #6 can be removed. Most just drill a small hole into the old seal and insert a screw to use as a pull point for removal.
Discussion Starter · #8 ·
I already removed clip#6. I have to remove the pump and open it up to replace the seal correct? Also, where do I get a new seal?
Thanks
Don't think the pump needs to be open, Anyway I see no reason to. Have you tried Gravely or an Ariens dealer near you? Jacks Small Engines #05608900 Seal .625x1.187x.187. at $23 dollars and some cents. I would take the dimensions and see what you could find else where before sending that.
Many seals can be bought in metric sizes really cheap. They are all pretty much Buna-N seals. 16x30x5 is the seal dimensions Ariens listed above. 16mm shaft size, 30mm seal bore, 5mm tall seal.
See if you have 3 (16, 30, 5) numbers like in the pic below on the seal. I just did my BDU-21
hydro and most of my seals were $3 or less when bought by metric sizing.
I drill a couple holes in them and pry them out with a prybar on a wood block so I don't hurt the case. Press your new seal in by hand and seat it using the old seal as a driver.
Discussion Starter · #11 ·
Don't think the pump needs to be open, Anyway, I see no reason to. Have you tried Gravely or an Ariens dealer near you? Jacks Small Engines #05608900 Seal .625x1.187x.187. at $23 dollars and some cents. I would take the dimensions and see what you could find elsewhere before sending that.
So I just drill a hole right here, screw a screw in, pull out the old seel and press the new one in (#05608900 Seal .625x1.187x.187. at $23 dollars )
Did it not have a clip and a washer there? But yes look like it down to the seal. I should have take a picture. Will try later today.
1 - 14 of 14 Posts
