1 - 8 of 8 Posts
There is a 316 parts tractor for sale close to me for $200.00. It has an 18 HP Onan which I found some 316's came with. I am thinking about buying it just because it is cheap. The owner has the tractor in pieces because he said the transmission is bad, all the parts are there in boxes. Does anyone know if the engines and drivetrain are the same in a 316 and a 318? Is there anything else that is different?
Pretty much the same, but the hydraulic pump *might* be smaller since the 316 was manual steering. It did have hydraulic lift though. So yeah, basically the same tractor.
John Deere 316 Onan
The drive line is the same. A ''newer'' 316 is basicly a 318 with less options like no PS, 1 hydro lever with 1 set of front hydraulic couplings, 1 brake pedal, ect.
If the engine is good $200 is a steal for that tractor.:fing32:
Addictionado
Hi you didn't mention if it came with a mowing deck but just the same many good parts that can be used on a 318 and $200 is a buy
John Deere 316 Onan
Discussion Starter · #8 ·
OK, thanks for the info guys. There is not a deck included. Im going to give him a call to see if its still available.
1 - 8 of 8 Posts
