1 - 11 of 11 Posts
I found a 58 Wizard this weekend and got it cleaned up and tuned today, it runs great a bit loud because of a crack in the muffler. Anyway the engine is stamped POWER PRODUCTS and is 2 cycle I found out these were only sold at western auto stores. It also says to mix 1 gallon of gas with 1/2 pint of 30 weight, should I stick to this or use 2 cycle oil? As you can see it has a bit of paint loss, should I repaint? Let me know what you guys think.
I'm with you es bob. I enjoy Lawnboys a lot but I have to say that I have a weak spot for vintage mowers of any brand, and vintage things in general. Not so much for their value but I really like seeing how things were made and what materials they were made of.
Nice machine, thanks for the pictures!
· Branded for LIFE !!!
I would stick with 16/1 straight weight 30....This engine might not have chrome rings..like the newer engines do..and its got bronze crank bushings..but its your engine..B,:trink40:
· Old engine addict
Chrome rings and bronze bushings don't have anything to do with what oil you burn in an engine. The reason they recommended regular oil back then is simple: 2 stroke oil didn't exist.
You CAN use regular 30 wt oil in it, but there's no reason to unless you like SMOKE and cleaning out your exhaust ports once a month...
1 - 11 of 11 Posts
