My IH350 utility won't stay running. Ran good last year, but now will only idle with full choke. Obviously starving for gas.
I suspect a gummed-up carb. guess I shoulda turned off the petcock last Fall.
Is a carb dissmantle straight-forward?
Is that a water tube bringing heat to the carb?
Anything else I should know (about the carb, that is) ?
thanks,
Guys
Im not an expert, but I just went though the same thing on my old 400. The carb break down is extremely simple! After I did it once, I can pretty much do it blindfolded. You probably have a stuck float, or a damaged float causing the pin to remain up, keeping gas from flowing. The tube to the left is the accelerator pump.
