There is a good thread here from the Cub forum showing a full install.
There are also notes from me on the install I did just using a used oil cooler and adapter plate. It all depends on how original you want it to be and how much money you want to spend.
Based on the information I feel that it is well worth the investment in either case to install the cooler as it will improve the engine life. In my case where I run the tractor 2-3 hours straight at high load I felt it was worth it.
On that note be careful how much you increase the RPM on the engines.
Usually the maximum is 3600 RPM for these engines but dependent on the application they are often derated down. I think Craftsman usually uses 3350 RPM.
