Today I started the process. There is plenty of spindle length to work with, the factory welded-on stop(washer) is at 3 inches. But there is 5 inches of usable length after you grind off the factory stop. I opened the hole on a heavy washer to 1" and will weld it on at 4.5". The new hubs measure 3.625" - outside to outside of the bearings. I opened a 1" hole in some 1.25" stock and will cut a .75" spacer for the inside for the rubber seal to run on and be the inside stop for the hub bearings. I plan on using a piece of 1/2-13 redi-rod for a stud(Joelk's idea) in the end of the spindle and a fresh ny-lok nut for bearing preload. While I have the front-end apart I will install new kingpin bushings, there was a lot of play in them, but with 1190 hours on the tractor I'm sure they are original. I'll post more tomorrow as it all comes together.
Bill
Bill
