I don't have that tiller but I'm sure it does not connect to your auto connect. You either need a rear PTO (as my 647 tiller uses) or your tiller connects to hydraulics.
Sent from my SM-G900R4 using Tapatalk
You want to connect this to Your X738 First You will need a New Pump Bracket and then a Different driveshaft end I have the Part Numbers Just need to Find them In My Private Message archive.I sure could use some help. I have a 2015 x738 with the auto connect setup for the deck. I bought and installed the Cat 1 3pt hitch for this tractor. Last year I bought a 42 Hyd tiller, great deal (so I thought), and unused. First problem I discoverd is that it's for a cat 0 setup. So I bought the cat 1 bracket to mount the tiller, and the 3 smaller needed brackets/parts to mount the pump on the x738. I can not figure out how to connect the pump to the auto connect part on the tractor. These are pics of the pump I have. Any help would be greatly appreciated. Thank you in advance. My 80 yr old brain is stuck in a 63 yr old body.
