Kohler 26HP V-Twin on a DGS6500.
Last year, The engine started making a surging noise when warmed up but not under load. I solved the problem by changing out the spark plugs.
The tractor has started making this noise again, so I changed to plugs and it's still doing it.
So i'm thinking if it is related to spark, It could be the wires...
But I don't know how to change them.. do I have to take apart the whole top of the engine to get to the (distributor cap/ignition coil?.. or am I using car terms to describe a completely different part on a small engine?)
Once I find them, does anyone know the specs for replacement wires?
OR - any other thoughts for fixing the surging issue? I've already investigated replacing the fuel filter and will do that as soon as my replacement part arrives.
Thanks
Thanks
