I have an LT190 with the 48" Edge cutting system (whatever that is ;-)
From the gator blades website it looks like they have two blades for my deck.
One looks almost exactly like a standard blade.
The other is more expensive, has "notches" on one edge, and is described as a 3-in-1, hi-lift, something or other.
I was planning on keeping my side discharge open. Is there any reason I should pick one of these gator blades over the other?
I was going to go for the more expensive 3-in-1 but I'm not sure if it's meant for my application...
Thanks!
Retired MTF Admin
Thanks!
The three in one should be the gators with the extra cutting edge..
I recommend them..Fewer/smaller clippings..:trink39:
The Magnificent
Yep, you should see a bit less wind-rowing with the 3-in-1.
They tend to reduce the clipping size thus spreading it better.
