Oh keep torturing me lol. That looks so nice. My back feels better just looking at that knowing how much easier work would be around here.
Check out Heavy Hitch and ALZWelding (although it appears Al is taking a sabbatical!)I'm going to make something to hang between my 3 pt lift arms that I can hang several hundred pounds of suitcase weights on...
Just be careful until you get that rear ballast all taken care of! If the rear wheels get light, that means all the weight of the tractor, FEL, and whatever's in the bucket is being supported by the front axle alone. Also, if you're not in mechanical 4WD, you'll lose braking power. Have fun and be safe!:thThumbsUA full bucket just barely left the rear wheels on the ground...
I have no intention of using the loader without counterweight. I just "experimented" in a level place to see if a full bucket was enough to lift the rear of the tractor.Just be careful until you get that rear ballast all taken care of! If the rear wheels get light, that means all the weight of the tractor, FEL, and whatever's in the bucket is being supported by the front axle alone. Also, if you're not in mechanical 4WD, you'll lose braking power. Have fun and be safe!:thThumbsU
There is an implement relief valve (IRV) already. But that doesn't protect the motive side of the transmission. So you have to replace the forward free wheeling valve with a Transaxle Hydrostatic Relief Valve (THRV). Rod at CTC might not agree about the necessity, but this is the procedure JD follows when mounting an FEL.Great loader, hoping to get a CTC next month, can't find a 45 around here. I know about the shut off valve but I thought that there was a relief valve already on the x7xx. Isn't this the valve that some members "trim" to get more lift capacity?
