Well it didn't take long after getting the 318 that I drug home another green tractor... Seems to be my style - you need at least 2 of each right??
It has a K341 with a two-piece connecting rod and free floating piston. Not really a good design for performance...
Side panels are there, just not on it at the moment. It is missing the grill though.
It's rough around the edges but seems like it has good bones. Seller said he just tuned it up, put new spindle bearings and belts on then mowed 3 times before it died.
I'm assuming the 341 will need machine work for both the crank and bore along with probably a 10/10 rebuild set. I want to say that's like $5-700, maybe more. Everything is more these days...
A HotRod 459cc 16hp Predator is on sale for $440... Will need a BFH mod on the one side panel. I'm reasonable sure it will anyway...
Then there's the Predator 670 22hp V-Twin for $949.
Not sure exactly what I'm going to do, but I'm kind of thinking aux hydraulics, FEL and Backhoe. 22hp would be nice but the 16hp 459 is looking budget friendly and likely enough.
Question for those that know these better than I do, could I add aux hydraulics and use the factory valves? The block or re-route the lines from the hydro? I think it would be neat for the FEL. Yeah, I could use the front ports but the speed would be slow.
