1 - 18 of 18 Posts
Lawn-Boy fan
Guys I'm parting out an M... I know that Sharkey wanted the SP and bail cables, and Timberwolf mentioned wanting the mulch plug. Aside from that I have the rest of it.
The wheels are junk, and I don't know if the trans is ok or not. The gas tank leaks and one wheel is cocked pretty bad... it needs a lot of work (and I have 2 others already) so I'm just parting it out. It is an M21EMR It has almost 150 psi of compression... 3 pulls got me that reading, cold. I never ran this mower.
Pics are attached, *--->>>please post in the thread first if<<<---* you want something... to be fair. What is left after a couple days here I'll throw on ebay.
Thanks
Bob
Administrator
Hey, Bob, you going to throw in a bottle of Amsoil with each and every purchase? Looks like you have a good supply there!
Lawn-Boy fan
No... lol...
I have amsoil fluids for the transmission, front end, rear end, and transfer case of my Jeep. Just need a good day with it to change all of it. That's why it is on the work bench.
2 stroke enthusiast
How much $ for the carb? Is it still there? Couldn't tell. You sure your gauge is reading right? 150 on that engine and it shoulda looked like Toby's Duraforce! A grenade in all it's glory! Unless it's heavily carboned in the dome, you shouldn't be much over 110-115 as a new engine would pull those numbers.
Lawn-Boy fan
Discussion Starter #11
Like I said, I never ran this one. Looking in where the carb port is, the piston is clean and so is the cylinder. I pulled 4 pulls and got that number. It is a Snap-On gauge so I'd hope it is right.
I do have the carb, PM me an offer.
2 stroke enthusiast
I've got a Lisle and most readings fall around 103-108, but I did pull 113 and 114 from my 10525 and M much to my surprise. I was beginning to think my gauge was reading low, though it's been well kept and never dropped. I keep my diagnostic tools away from heavy stuff like sockets, ratchets, etc.
Lawn-Boy fan
Discussion Starter #13
This stays in its case in a drawer next to pairs of gloves... lol.
Good running F's usually read 105-115 for me.
Bob,
If none of the regulars here request it, I'd be interested in the transmission for pilfering a couple of parts (2nd gear, shift collar/spring/key).
Got an unresolved second gear problem on my 10590 and might resort to testing via part swaps. I recall a post on here (somewhere, can't find it now) stating that pretty much everything inside the tranny case on a 1059x was the same as in the M21xxx. At the very least, I could probably use it to compare wear depths, etc. to figure out my problem.
I also realize you'll probably do much better selling the tranny to someone needing the whole unit, on eBay, etc. vs. what it's worth to me (as I'm not sure *what* I need).
But, if the transmission is still left over after all is said and done, let me know.
Jon
5K Poster!!!
You say the wheels are toast but are they this bad? If not I would take the better of the two.
I could also use the plastic muffler cover (green) How much?
I could use a coil for an M. I believe they are the same as the ones on the DF's. PM me with a price. I may think of some more parts shortly. Thanks Bob!
Lawn-Boy fan
Discussion Starter #17
Thanks for the inquiries. I've had a few private messages regarding this and I'm sorting everything out based on what time people contacted me. I will get back to you guys tonight.
Bob
Lawn-Boy fan
Discussion Starter #18
So far, whats gone...
Rear wheels
Mulch plug
Flywheel brake
Oil fitting from fuel tank
Bail / SP cables
Air filter / muffler cover plastics
Still have carb, recoil / shroud, bail handles, knobs, etc etc
John, you're first inline for the coil I just need to check if it has spark as I never ran this mower.
Bob
1 - 18 of 18 Posts
