1 - 14 of 14 Posts
I got an Allis Chalmers big 10 for 30$! It's in good shape but has no grill. It's got a blade and deck. It has a 1978 Briggs on it but it looks like a 1965. Is that not the right engine for it? It does run and move and it's got 1 new tire on it. Not too bad for $30!!
Discussion Starter · #2 ·
I need the part for the front of the deck that holds it to the front clips does anyone got one? Thanks!
If you could post a picture of the deck you have showing what you need, the decks were a little different in that area depending upon which model and size. I have a couple parts decks and might be able to match something up.
heres some pics of it. its only got 1 rust hole in the battery tray. Man o Man does this thing have some serious power. Its an AWESOME motor on this! I tried to show where the deck is supposed to go but im missing the piece. Im not sure what the blue tape is for. Its just there. Thanks
I may be wrong, but I thought that the two arms on the mower deck slip into the two pieces coming off the front axle and are held there with pins.
The deck then follows the front wheels as they move over high and low spots thereby minimizing scalping.
Brian G. NY
Discussion Starter · #8 ·
Sorry about the terrible pics. When i put the brackets up to the ones on the tractor i cant steer at all cause the deck is so close.
Discussion Starter · #9 ·
heres a few pics of what i mean too close.
Discussion Starter · #11 ·
thats what i figured was the issue. Ill call the seller and see if hes got them since hes the one who took the deck off of it to put the snowblade on it.
Here are some scans from the manual showing the pieces and the installation.
The 1st pic is the newer style. The ones you need are in the 2nd pic.
Discussion Starter · #13 ·
Wow thanks alot thats really helpful!
Discussion Starter · #14 ·
well i havent heard from him so i am in need of the holder. On the diagram its called the rocker arm. Does anyone have one??? I did get it running great since it did leak gas like crazy and i did replace the float since it was cracked open. Man this thing really runs though! And it really scoots for only 3 gears.
1 - 14 of 14 Posts
