Hi all, I just replaced the clutch in my B. Clutch disk, pressure plate, pilot bushing, throw out bearing, and the ring gear on the flywheel along with facing the flywheel .030 thousands.
The clutch is not releasing properly, the fingers on the pressure plate are adjusted out as far as they will go and the clutch rod is adjusted out as for as it can go and still having a couple of the threads still engaged in the clutch fork. I'm out of adjustment.
I have to start the tractor in gear because it will only grind if you try to put it in gear while running.
I removed the starter and when the clutch pedal is pressed the disc is free, not squeezed between the pressure plate a flywheel.
When I push in the clutch the tractor stops moving but if I kick it out of gear I can hear the transmission shaft turning as soon as it's out of gear with the clutch pushed in.
I'm 99% sure the clutch plate is not in backwards. I was very deliberate about making sure it was correct and looking through the inspection hole in the bell housing the long end of the splines is facing the rear of the tractor. Any ideas?
