The last step is to bolt the cover, which holds the spur gears and stub axle, to the kin pin housing. It went on easily. Torque the cover bolts to about 20 ft-lbs and the king pin bolts to 60 ft-lbs. There is a little cutout on the axle hub that allows you to access the bolts.
By the way, I forgot to order gaskets, so I made my own.
I had about 2 hours into the one side that I did today - I didn't have any reason to hurry.
Glad to be of help. Hardest part was finding the parts...I have a brand new large gear if you need it.
Mitch
Insert the stub axle through the oil seal. Flip the casting over and install two of the bearings. They fit loosely into the bearing pockets in the casting. All it took to seat them was a light tap with a big dowel rod. I bought a sealed bearing to replace the original small unsealed bearing at the top of the casting. I did this because these bearing were rusted badly in both final drive units.
...the post you are quoting is from 9 years ago, and MitchK hasn't logged into the site since 2016. You are unlikely to get a response from that user.
I cajt figure out how to get the blind hole bearing out of the housing
