All this talk about the oil pump drive gear failing got me to add an oil pressure "Idiot Light" to my 4514. There are only a few things I could come up with that would cause the plastic gear to fail. One is wear as LarryCCF mentions and another might be if the wrong weight engine oil is used in cold weather. The owner's manual shows a chart of oil weight vs. temperature and specifies that 10W30 or 10W40 should be used for temperatures down to 0*F. If a heavier weight oil is used or a straight 30 weight, it will put more stress on the gear. Another possibility is a clogged oil filter. I don't think Honda uses a filter bypass valve in the block. If the filter clogs the gear will be heavily loaded. To ease my mind the light I added may give me a little time to shut down the engine.
Honda specifies the oil pressure at 2kg/cm or 28.4 psi for this engine. I found a switch made by Autometer that will turn a light on with a pressure lower than 18 psi.
Here is a photo of the main oil gallery on the spark plug side of the engine. The fitting for a sender is blocked off with a plug. Unfortunately Honda put a motor mount just below this plug.
I had to grind away some of the mount and use a 45* fitting to allow room. Here is a photo of the sender installed.
The idiot lamp is made by Dorman and uses LEDs.
Here is how it looks on the dash. The "Low oil pressure" label was made using my printer and is held under some clear packaging tape.
Wiring for the idiot light was simple. I used a switched +12 volts from the ignition switch to go the lamp + terminal and from the lamp - terminal to the pressure switch. This pressure switch will connect to ground with an oil pressure less than 18 psi.
