I go with water cooled and Yanmar diesel, as mice cannot stuff the air shroud with nesting material (neighbor had early death of his air cooled engine running with a nest and cooked the engine) and the Yanmar diesels in my JD 455 and 4300 are unmatched, IMO.Looking for an older {affordable for me) JD mower/garden tractor - maybe GX series. I'm not sure I'll have a choice but I would like to read opinions on the Kawasaki air cooled vs the water cooled. I'm leaning toward the water cooled but it does add another system to maintain.
Also, while here, comments on the Yanmar diesel,
Thanks, Bob
Good point about the mice factor.I go with water cooled and Yanmar diesel, as mice cannot stuff the air shroud with nesting material (neighbor had early death of his air cooled engine running with a nest and cooked the engine) and the Yanmar diesels in my JD 455 and 4300 are unmatched, IMO.
Neighbor has a 3-4 yr old Kubota diesel in his RTV X1100C and it has been a hard starter in cold weather.. not a good thing in WI. But is completely decked out with a V-plow and cab with all the luxuries. As an aside, I helped him out with my new Portable Li-ion jump starter to get his dead battery in a -10° F morning up and running again.
Impressed me what that little egg-carton size battery package could do as a 12v jump starter. The $100 investment is good security.
Volcano2000Good point about the mice factor.
I agree that the GOOD Li-ion Jump Starters are impressive, but not sure all of them are good. Exactly what model did you get?
It depends on the Vehicle with That statement I have several 60 year old Plus air cool engine that are still running strong In equipment I own Liquid cooling only Came to the JD Line of outdoor Power equipment in 1983 with the JD 430 Most of the Machines In My signature are air cooled except for My 1993 Cub Cadet 2182(Kubota Gas), 2012 JD X748(Yanmar Diesel) & 2018 JD 2025R (Yanmar Diesel)air cooled don't last as long.
Just found the YT video of the diesel engine in the excavator that was started using a Li-ion jump starter that impressed me enough to order one, and now realize it is the same one I purchased off Amazon. TopDon Volcano2000Volcano2000
Off Amazon..
that may be true but i found the cost to do a complete rebuild on my yanmar was higher than buying 2 new gas engines and then you need to factor in the original purchase price increase! may be different in usa but when I priced pistons,crank,rods, bearing ,gaskets it came to over 3k cnd. and that's not including labour/machining and all the external components that are wore out!I don't own any diesels(I don't put thousand of hours on my stuff), but from what I have seen it seems to me that much longer engine life should be at/near the top of the list of diesel benefits.
How many hours were on the Yanmar when it needed rebuilt?that may be true but i found the cost to do a complete rebuild on my yanmar was higher than buying 2 new gas engines and then you need to factor in the original purchase price increase! may be different in usa but when I priced pistons,crank,rods, bearing ,gaskets it came to over 3k cnd. and that's not including labour/machining and all the external components that are wore out!
I got rid of the diesel simply because my fuel costs are split 42 ways. I worked on highway tractors for years and Low Sulphur diesel stinks!
I'd drive a gas truck if I could find something that compares to my 6.5TD for mileage. my son is a gm tech and he sold his duromax to go back to 6.5!
this is getting off topic of air/watercooled! my.02 diesel for farming/commercial landscape, gas for residential grass/snow ,watercooled for extreme hot locations!
2210 was Introduced 9 Months after the X400/X500 Heavy Duty series( Introduced in Sept 2001 But Not releases for sale Until Jan 2002) at the 2002 Dealer show In September for 2003 Model year. Backhoe wasn't Introduced Until the 2305 Came into Production. Had several Members over On the Garden webs Tractor forums that Upgrades there 2002 X500 series 4WD models to a 2210 in 2003I have a x595, which i guess is a super GT? LOL it's a great machine - lots of power, hydraulics work good (after you boost the pressure a little). When i bought (used) it many yrs ago - the 1023 & 1025R , 2210, 2305's were not out yet. I would have seriously looked at them too. My budget only went so far, at the time the 755- 955 series were top dollar. THe only issue is if you want a 3-pt rear lift or rear PTO, you have to find the parts and add it on. The 3-PT operates off the mower lift, which is the same circuit as the bucket roll. I would like to add a 3-PT at some time - but i have to separate the hydr. functions and space under the tractor is very tight to say the least!!.
