Putting an air compressor on a tractor is something I have been thinking about for a while. Received a compressor head with a load of scrap metal. Mounted it on my 126 cub. It is belt driven from the pto on the cub ,,,mounted a used air tank on the roll cage ,The air tank has a relief valve. Have 20 ft of air hose for filling tires. Doesn't have a pressure cut out switch, let it run for 20 minutes with compressor running ,,,it never went above 120 lbs. the old compressor won't pump any higher than that. The cub has a hitch on the front for moving trailers,and the air will be handy for soft tires.
