1 - 3 of 3 Posts
The item pictured is the cover for the back end of the float spool. It's longer than the other cover to accommodate the extra length of spool required for the float detent mechanism.
Your fluid escaping is most likely due to worn O-rings in the valve body that seal around the spool. Changing them is not difficult or expensive. Disconnect the control levers from the spools and remover the covers on the other end of the valve body. and slide the spools out. There may or may not be retainers to access the seals themselves that have to be removed in order to slide the spools out to access the seals.
1 - 3 of 3 Posts
