1 - 3 of 3 Posts
5K Poster!!!
Does Stens or Rotary or Oregon make any descent aftermarket trimmer heads?
I'm fixing up my old Fuji Robin trimmer cause its light as a feather and I'm needing a new head for it. Has anyone ever used any of the aftermarket trimmer heads? Any good?
Does anyone have a head for a Robin NB2001A they would like to sell?
Junk collector
My local Lowe's sells universal Shakespeare line heads. They come with several adapters and are around $20.00 each.
A semi-retired senior cit
If you go to Lowe's look at the Husqvarna T-35, see it that will thread onto your Robins shaft. They are a good and easy to load trimmer head they are not to heavy and wont slow you trimmer down, They do make a smaller one I think it might be a T-25 uses .080 mil string same easy to load. What I like about the trimmer head is the only one loose part inside and your going to be wrapping trimmer line around it, has a big blue button on the bottom to tap to advance the trimmer line. When done loading just line the clips up and push it back on until it slips into place and you should hear a click.
here`s a link to the T-25
http://www.tractorsupply.com/outdoo...qvarna-reg-t25-trimmer-head-with-line-4457267
here`s a link to the T-35
http://www.tractorsupply.com/outdoo...um-force-string-trimmer-line-50-ft-95-4431677
1 - 3 of 3 Posts
