You will not have to worry about putting too much weight on the aerator. They are designed to work with just about any weight you can put there.
Jerry
You will not have to worry about putting too much weight on the aerator. They are designed to work with just about any weight you can put there.This will be my first time aerating with the x300. What is a good amount if weight to put on the aerator as to do a good job, but not over tax the engine/transmission? Thanks!
Can you supply additional information?Your asking for trouble.
the above poster has a X748.....that is why he can put that kind of weight on it.Two 80lbs bags of concrete always seem to be enough for my lawn and soil condition.
I have an older x304 with the slightly beefier K58 transmission and I load up my 48" plug aerator with 6 cinder blocks (tray completely full) when I aerate once a season. I try to keep moving and optimize my hill ascent angles, and the tractor has performed well in this task (without any ill effects so far). We have red clay soil here in Georgia, in case that makes a difference. I would expect an x300 to perform similarly but hopefully your yard is pretty flat (and your soil looser). You should only load up as much weight as necessary to guarantee good ground engagement (penetration), so if you can get away with only 3-4 cinder blocks, I recommend not exceeding that amount.
I wish my neighbor had a dethacher so I can trade him my aerator.Incidentally, if you get an aerator, your neighbors will eventually want to use it too.
K46 transmission is all the info you need.Can you supply additional information?
Perhaps if he was pulling uphill for extended periods of time.The engine will not be an issue. It will have plenty of power. It's the trans you need to be concerned about.
Also lots of people with flat yards who have done nothing more than pull a cart who have trans problems after a couple hundred hours. Glad yours is working out though. Not many people have had your experience. To the op. try it out. If it works good than go for it. First time I tried to pull any weight with one it was obvious that it was a bad idea and hasn't been the same since. Best of luck.Perhaps if he was pulling uphill for extended periods of time.
Sounds like he has got a pretty good handle on things,(along with his terrain makeup) with some helpful advice
If you run the engine at full throttle to keep the cooling fans/pumps at the optimum speed he should be fine. Know how to use your machine.
Plenty of people have a lot of hours on these machines with little problems,as they usually know how to use their machines. Something to think about perhaps...
Most of these people don't find the need to post-just the negative ones seem to have a need to make their opinions known, offering little real, or helpful advice-just one-liners.....etc.etc....
Amazes me those that shiver to hear a k46 doing some work.
I don't have a X300, a X310.Also lots of people with flat yards who have done nothing more than pull a cart who have trans problems after a couple hundred hours. Glad yours is working out though. Not many people have had your experience. To the op. try it out. If it works good than go for it. First time I tried to pull any weight with one it was obvious that it was a bad idea and hasn't been the same since. Best of luck.
Sent from the MTF Free App
