1 - 2 of 2 Posts
Just finished the rebuild of my 990 and took it for the initial test drive. Since all of the linkages where completely disassembled for paint / repair, I know everything is off. I have to hold the hydro lever all the way fowards to move, if I let go of it, the tractor stops. Currently to get reverse, If I push the brake pedal all the way down, the tractor will go backwards. Which adjustment do I need to start with to get closer?
The tapered shaft on the bottom of the hydrostat needs to be able to turn an equal number of degrees in both directions for proper forward/reverse. There's a partially threaded rod connected to a cast piece that fits onto that tapered shaft on the hydrostat; by adjusting the nuts on the forward end of that rod you'll get the proper amount of back/forward movement.
Not very easy to explain but it should make sense if you stick your head under the tractor and watch how things move when the forward/reverse is adjusted.
1 - 2 of 2 Posts
