i have a 420 and one side of the deck is sitting lower than the other. how do i adjust the deck?
I am by no means a JD tech but with my 420 and 50 inch deck I set the side to side height by extending or shortening the hangers on either side. If you follow the yellow supporting arms back you will see a threaded hanger. If you take the pin out ( after supporting the deck)you can rotate these 90` and take them off, or just turn in the one you wish to shorten(a little bit does allot).
Cutting height is set by the threaded rod in the very back end, below and left of the gas cap- has a pin sticking through it. Raise the deck, screw this out a little way, then lower the deck to the desired height, then tighten the threaded rod until contact. This acts as a stop for the deck height.
I hope this helps
Yamadoo
