Definately needed if it's not too much trouble ? Thanks , Keith
Hi Joe, what length cylinder did you use for your p/s ?
I was thinking of doing something similar to that, I was going to put power steering onto a JD317. I was looking at the breakdown of the 318 power steering hook ups, & found out that 2 of the ports go to a cooling unit for the hydraulic fluid.
Wow... after reading how complicated and expensive a power steering system is I am so demotivated to do this! I was hoping to just run the system off of the hydro tranny but that sounds like a bad idea now too :-\ What should I look for for a used valve? Is there a specific type of steering valve that would be easiest to setup?
-Jordan
Jordan , you can buy a brand new steering valve for $149 from Surplus Center and a 1x6" cylinder for like $89, less than $250 for the main components. But hoses can get $$$$ . Don't give up , it only takes time and patients and a little $.
