1 - 8 of 8 Posts
I'm considering the purchase of a JD 425 with rear pto and cat 0 3 pt hitch (pic attached)
I assume that I will not be able to locate JD 450 tiller and will need an aftermarket unit.
I've never owned a machine with a rear pto or 3 pt hitch, how can I tell if a tiller attachment will fit the 425?
Thanks
2501893
Looks like you are missing some pieces, PTO stub shaft, lower lift arms, top link, at least.
It looks like the 540 RPM PTO on a 425 is a standard PTO. I think you can get limited cat 1 arms, which would fit a standard tiller that isn't too heavy or too tall.
Pictures and more info here:
You might have to watch for a little bit, but you should be able to find a 450 tiller out there. Granted, you might have to buy a machine with the tiller and resale the machine itself.
As mentioned it does look like you are missing a couple parts.
Noticed a 450 tiller near Philadelphia posted on Craigs List 2-3 days ago. Not mine.
Thanks, I saw that too. It is missing the skid plates. I wonder how hard it would be to replace those?
The skid plates were/are optional. I have a set for my 42 hydraulic tiller and I have never used them. The depth stop on the tractor does a good job at regulating depth if desired. The skid shoes themselves are part number M115872 and are $300 each!!! Most tillers do not have them.
Thank you for that information, I appreciate it. I've never seen one without skid plates/shoes before.
42-inch hydraulic tiller. If you buy the 425 you may want to research those. (M04390X######) JD parts catalog - PC 2697.
Think there is/was a type that operated from a 425/445/455 rear pto. Finding that and all the necessary parts/pieces would probably not be easy either.
1 - 8 of 8 Posts
