Off to a GREAT start! :thThumbsU
You will be raising and lowering with a winch, is my guess.
Thanks. Tactor has lifting hydraulics. I'll be connecting to that system.Off to a GREAT start! :thThumbsU
I had to look up "osculate" to get your meaning. I learned a new word. You're right. It will not pivot side to side. Only floating length wise. I think I understand. Fortunately, the "holes are small and should fill easily. I don't think this will be a problem in my case, but I will keep your suggestion in mind. I'm going to just tack the end wings so that I can make mods later if need be. I'm close to being able to test what I have, so far.The beam does not appear to be able to osculate in relation to the rear axle.
If it does not osculate on the hitch, you may find that using the drag in reverse will fill holes better than going forward.
Having the fixed axle trailing the drag will have the fixed axle running on filled holes rather than running down into them.
I mention this so that you may consider extending the wings to the rear also.
Rear extension of the wings will also give more leveling effect.
IMHO
Do they have purpose going forward? Or just backing? I can always add them. Nice thing about having a shop and equipment. I'm certainly not versed in implements, so this is an ongoing experiment.I speak from experience that you need rear wings.
I did not put them on when I built this!!
:crybaby:
Yes they work going forward as well!! They stabilize the grading edge to keep the blade "more level". Three foot long would be better, but, would get in the way!!Do they have purpose going forward? Or just backing? I can always add them. Nice thing about having a shop and equipment. I'm certainly not versed in implements, so this is an ongoing experiment.
If more weight is needed, I can fill the top of the beam with concrete. If it is OK without more weight, I'm thinking about welding a cap over the top to keep it from filling.looks nice. a place i used to work used an I-beam drag and rock an gravel would pile up on top of it which wasn't bad for it it made for more weight and better cut in but with down force u may not need the extra and cutting the front edge off may help. to much down force and you'll lose traction.
Thanks. But will it work? I'm thinking I may paint it first, then test. That way I won't have to clean mud off of it first.wicked cool!
