I'm jumping in here late with a thought. I had a similar experience with a portable generator. The issue I found was a faulty oil pressure sensor. It ran perfectly after replacing. Jim G.
9N doesn’t have one. It has an ammeter and an oil pressure gauge. That’s all. We are talking 1939 technology here.I'm jumping in here late with a thought. I had a similar experience with a portable generator. The issue I found was a faulty oil pressure sensor. It ran perfectly after replacing. Jim G.
The idle jet works bass ackwards. In reality it is an air bleed. Turning it in reduces air flow and makes the idle mixture richer. One rule of thumb is to start 1 to 1&1/2 turns out and turn it in until you get a smooth idle without pop-pop-popping in the exhaust. The popping is indicative of too lean a mixture.Do I need to mess with the idle adjustment more do you think? I just set as per recommendations, and did not touch it after that
What resistor did you replace?Do I need to mess with the idle adjustment more do you think? I just set as per recommendations, and did not touch it after that
It’s starting to sound to me like there are seriously plugged up passages in that carburetor. Once again, I’d swap it for a rebuilt. When I rebuild one I soak it in carb cleaner for a couple of days, back all of the jets (3 of them) out with screwdrivers ground to fit, rod all of the passages out (welding tip cleaning rods work - cheap at Harbor freight. Then replace everything in the carb except the float. That means new jets and the little brass cylinder that bleeds gasoline into the air stream. I also replace take the flappers off the throttle and choke shafts and inspect the shafts. If worn, I replace them and use new shaft seals, not forgetting to Locktite the screws.Do I need to mess with the idle adjustment more do you think? I just set as per recommendations, and did not touch it after that
Great. 12 volt conversions usually have an aftermarket second resistor. That’s why I’m asking.
fuel flow seems fine.Great. 12 volt conversions usually have an aftermarket second resistor. That’s why I’m asking.
make sure that you’re getting a good fuel flow to the carb also. When you take the fuel line off is should pour out, not drip drip drip. Sometimes people cut the line and put in a cheap plastic lawnmower fuel filter that plugs up and restricts the flow. For that matter the screen in the fuel bowl can plug up with rust, too.
Backfiring is due to unburned fuel in the exhaust system. The only way that unburned fuel can get there is if there is no spark and no ignition in one or more cylinders. The failure to spark can be intermittent - just enough to get raw gasoline vapor into the exhaust manifold and down to the muffler.New carb has made no difference. Same story. I can get her to run more or less first time, under load. Letting off the throttle kills the engine. After that first run, she won't start at all, till the next day, or hours later. A lot of carb valve leakage while trying to turn over the engine also.
New idle adjustment screw is a pain to reach. The old one was finger turnable.
There was a big backfire this morning too.
