so i guess what i don't understand, is if i set the blade 1 inch off the ground and hit something it won't float up the pile?
It will float over something it does not catch under, like a pile of dirt or gravel, because the hydraulics do not have down pressure. This can be helped somewhat on a back blade by the angle/pitch the blade is set to.
I mean if your plowing wouldn't you want it to not float?
If it did not "Draft", adjust to the load the plow is applying to the tractor you would spend all your time moving the plow up and down manually as you encountered harder ground and your tires spinout. Draft control does the work for you, mind you it is not making MAJOR adjustments up or down to the plow, just enough to keep you turning dirt.
