9N pto seal repair question
12174 Views 6 Replies 5 Participants Last post by  Steve (Magnolia, TX)
I have found several "how to's" on the newer 8N pto seal replacement. but the diagrams of the 9N seal arrangement look much different than the 8n.
Is the 9n pto seal removal/repair/replace significantly different from the 8n?
The diagrams seem to show a ring of packing and not a "seal" in the 9n.
Help!
1 - 7 of 7 Posts
PTO seal is the same for 9N and 8N..
Check out Just8N's
Check out Just8N's
Only if the original 9N PTO was replaced or upgraded. The early machines had a "funky" seal assembly. Check out this web page for information:
http://www.tntwebdevelopment.com/tff/9NPTOSeal.htm
My suggestion if you still have the old PTO style shaft is to replace the whole thing. It will come with an 1-3/8" PTO and a normal lip-style seal. If your trying to keep the outside of the tractor looking original, I hear that you can switch out the new steel bearing retainer with your old cast iron one. Not sure if any modifications are needed though.
-Leon
Thanks for the info, learn something new every day..
Seems like it applies to the '39 to'43..OP take note..
Altho I leave my ORC on all the time, I would consider upgrading to the 1-3/8 also..
-Leon
Excellent info. guys!!!
looks like a simple job. I hope to get to it next week.
Thank you,
Rick
if it's the newer one.. it's simple.. pull shaft and bearing retainer.. remove top inside snap rin. tap shaft spline external end on ground.. bearing carrier should fall off.. then it's just seals and snapring replacemnet.. inspect bearing and seal surface..e tc..
soundguy
When you go to do this... you're liable to loose a whole bunch of your hydraulic/transmission/differential oil.
Unless...
You can park the tractor with the front wheels in a ditch (or some other means of lowering the front end) causing all of that oil to pool in the front of the casting and change your PTO shaft out like that.
Of course... if you get it at too steep of an angle... you'll find out if the front seal in your transmission is leaking, too... :hide:
1 - 7 of 7 Posts
