1 - 3 of 3 Posts
Doing it the hard way
I have a 9N ford tractor (or so I call it 1945 serial# with electrics)
The free play in the clutch pedal is just too much according to the book, all the take-up in the rod is taken up as far as possible.
I am thinking there is a problem with either...
the rod being too long
lever on bell crank having slipped
bell crank damaged
throw-out bearing somehow wrong
What I need from you good people
measure the length of the clutch rod from eye to eye
and maybe take a pic of the bell crank lever when properly adjusted and clutch pedal released.
Thanks
Before doing anything I would check to be sure the bell crank has not slipped on the shaft.
1 - 3 of 3 Posts
