i had the thing cranking fine before i took the starter off now its back on and everythings wired and grounded correct and it wont crank at all:00000060:
Test The Starter..Use Jumper Cables.Clamp the positive to the Wire terminal. Touch the Negative to a Good/convenient Spot on the Starter Housing Somewhere and see if it Cranks. I normally put the Clamp on to the Positive and Touch the Ground so that WHEN YOU MAke Contact and Get the initial Arc/Spark when making Contact,you dont Bugger/melt your Positive Wire terminals Threads.Once you have your Starter varified as Working fine,you can go Backwards and Hunt down the Fault..Might be Coicidence ,but the Starter may have Died on you..Strange things can happen..
its easy to jump the solonid or starter relay on most riding mowers. you can also measure if voltage is getting to the relays coil. Might work better than a hammer
LOL That`s the Problem .You used the Cheap, Duct Tape to install the Starter.It`s not Grounding Properly, through the Shiny side like it`s supposed too. LOL
:sidelaugh but no seriously, some of the starters on the opposed biggs after they sat for a while, you could rap on them witha hammer and they would starter to work again. usually not a permanent fix.
yea im gonna do that tomarrow today i went to tractor supply and picked up some new paint it goin to be AC orange and i also picked up the new terminal so i hope after all of this she will turn even tho i need a new coil for it to start:fing20:
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
