So we pulled the columbia out today & gave it a once over to see whats missing/needs fixed ect. I noticed the wiring has been hacked/burned pretty good in places & looks to be hooked up wrong at the voltage regulator. As you can see in the pic its hooked up as red/green/black - the manual says it should be green/blk/red.Can anyone look at theirs and confirm? I also noticed the black wire is completely burned all the way from the regulator to the key switch so that will need redone to. Also what size fuse do you guys run from the amp gauge to the battery? there isnt one in there and the manual doesnt mention it.
We was wanting to sell this 990 but i think jodi is having second thoughts now & wants to keep it if we can get it running.... thanks for any help
