I started roughing out a cab design for the 990.
I am looking for some general input.
Right now I plan on using 1" square tubing .065 wall for the frame and the door will be made of 3/4" square tubing .065 wall.
I have a JD Squared model 3 bender and will be making some square tube dies in the needed radi.
I have'nt decided what to skin it with, maybe Aluminum, Fiberglass sheets, or some sort of plastic like ABS.
I plan on using either VHB tape or panel bonding adhesive to hold on the skin.
I also need to source a Windshield wiper.
I came up with a heat exchanger Idea, which consists of a copper coil wrapped around the exhaust, going to a modified rear heater from a Suburban.
Criteria for this design:
1. Has to be able to be mounted with one person.
(Hinged rear, two bolts in front)
2. Needs to have provisions for opening the hood.
3. Needs to not damage any sheetmetal.
4. Needs to be warm
Scott
4. Needs to be warm
Scott
