1 - 2 of 2 Posts
hi everyone, have a quick question . im putting the motor back in and while i lined up the u joint on the motor and locked it down i rotated the joint to check it , i notice the drivshaft end of the yoke with the rollpin in it has play in it . my question is should the driveshaft be a tight fit into the yoke? i cannot understand why that would of worn out.the ujoint is fine. thanks:duh:
It should be a slip fit, without noticeable play.
These engines generate alot of harmonics and the crankshaft doesnt rotate in a smooth,constant manner like an electric motor does as the piston and connecting rod actually drive the crank.
If you were able to watch a crankshaft turn in super slow motion, you will notice the crank turn slow and fast at certain angles in the revolution.
These harmonics are hard on everything.
Hope this helps
Scott
1 - 2 of 2 Posts
